-   -   Can RMS velocity even be smaller than mean velocity? (http://www.cfd-online.com/Forums/fluent/102123-can-rms-velocity-even-smaller-than-mean-velocity.html)
lgas222 May 22, 2012 22:57
Dear all,
I'm using the mixture, k-e, air-water two phases model in FLUENT to simulate bubble column. I calculated with transient mode.
After calculation, I checked the results: RMS velocity magnitude and mean velocity magnitude. I found out that RMS value is even smaller than mean value. Does anyone know how can it be like this? Is there anything wrong?
Thanks a lot.
Far May 23, 2012 01:17
It can be. RMS is the root mean square of fluctuating components that is u',v' and w'.
lgas222 May 23, 2012 04:18
Thanks for your reply.
I have one more question: is RMS calculated as ((x1^2+x2^2+x3^2+...+xn^2)/n)^0.5?
Far May 23, 2012 04:26
I guess so.
Far May 23, 2012 04:36
Some links are shared here, where you can find the discussion about the RMS velocity
http://www.cfd-online.com/Forums/flu...ity-ratio.html
