Help with convergence !
Old   May 8, 2012, 14:22
Smile Help with convergence !
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
i've been doing simulation on an supersonic air intake shown below. residuals can't go below 4e-3 and don't look like a straight line. i started with very low under-relaxation factors and courant number of 0.1. it took me 800000 iteration to get to the residuals shown in attached pictures. i'm using ideal gaz with mach number equals to 2.5
the mesh is hexa, all of it. quality is pretty good. (< 0.5 in 3x3x3 determinant)
Solver is steady density based. I'm using standard k-w for turbulence.
Flux type is AUSM because of presence of shockwaves
Gradient is green-gauss cell based. Second order upwind for the turbulent kinetic energy and specific dissipation rate and first order upwind for the flow.
I'm not sure of the result i'm getting.
Anyone doing same research here ? any suggestion ??
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   May 8, 2012, 14:58
me3840 is on a distinguished road
Try starting with a first-order solution. You should consider refining your mesh where the shocks are present. The simulation will be very sensitive in those areas.
me3840 is offline   Reply With Quote
Old   May 23, 2012, 12:35
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
it is also possible that flow is transient somewhere.
Use solution steering it will automate the process of changing courant number.
Far is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Time step dependence of convergence behavior of steady state simulations in CFX Chander Main CFD Forum 5 December 23, 2013 05:31
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
