Alias problem when starting FLUENT from command line
Old   May 24, 2012, 08:20
Default Alias problem when starting FLUENT from command line
TD
batch_error is on a distinguished road
I'm having trouble starting FLUENT from the command line. Up until now I have been using the GUI, started through the launcher, which I had set using an alias of 'fluent':
alias fluent='/ansys_inc/v140/fluent/fluent14.0.0/launcher/lnamd64/launcher1'
Now all the help manuals say to start process with a batch file using (for example):
fluent -g 3ddp < myproblem_01_input.jou > myproblem_01_output.txt
So I removed the launcher alias, and tried:
*****@*******:/fluent/equiv/fluent -g 3d < rect20input
Now, of course, I get a 'command not found' error for fluent, so my question is to which file should I point the new alias of 'fluent'? The fluent/ directory has dozens of different executable files and I can't figure out which to use - I've reproduced the directory below.
*****@*******:/ansys_inc/v140/fluent> ls
bin  commonfiles14.0  contrib  fluent14.0.0  info  lib  lib3.0  license  utility
*****@*******:/ansys_inc/v140/fluent> ls bin
archive         fluent-cleanup.pl  lmgrd     lm_run      netscape.remote  place4.mpi        utility
fluent          fluent_sysinfo     lmhostid  lmstart     place1.mpi       place4.vmpi       videocmd
fluent_arch     lmcksum            lmremove  lmstat      place2.mpi       Read.Me
fluent_arch1.0  lmdown             lmreread  makeshared  place2.vmpi      sge_launcher.csh
*****@*******:/ansys_inc/v140/fluent> ls fluent14.0.0/
addons  client  cpropep  ic3m  isat      launcher  lnamd64    packages  src    vki
bin     cortex  gtpower  info  KINetics  lib       multiport  realgas   tgrid  wave
*****@*******:/ansys_inc/v140/fluent> ls fluent14.0.0/bin/
fluent
*****@*******:/ansys_inc/v140/fluent> ls fluent14.0.0/lnamd64/
2d    2ddp_host  2d_host  3d    3ddp_host  3d_host  syslib
2ddp  2ddp_node  2d_node  3ddp  3ddp_node  3d_node
*****@*******:/ansys_inc/v140/fluent> ls fluent14.0.0/lnamd64/3d
fluent.14.0.0  localize.h
*****@*******:/ansys_inc/v140/fluent> ls fluent14.0.0/lnamd64/3d_host
For the curious, my batch input file is:
*;*Read*case*file*
 rcd*rect20.cas
*;*Calculate*50*iterations*
 it*500
*;*Write*data*file*
 wd*rect20-batch1.dat
*;*Calculate*another*50*iterations*
 it*500
*;*Write*another*data*file*
 wd*rect20-batch2.dat
*;*Exit*FLUENT*
 exit*
 yes
Thanks for any help!
[EDIT: My input file doesn't actually have all those asterisks, they appeared when I saved the post... not sure why, but they're all meant to be regular spaces.]
batch_error is offline   Reply With Quote
alias, batch, command line, fluent
fluent convergence problem josip76 FLUENT 0 May 26, 2011 20:08
Problem running a parallel fluent job on local machine via mpd highhopes FLUENT 0 March 3, 2011 05:07
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 13:31
Error when starting Fluent 6.3 on Pc with lnia64 architecture Julian K. FLUENT 1 March 15, 2010 23:49
starting fluent under freeBSD4.9 Herakles FLUENT 0 June 2, 2004 09:05
