Home > Forums > FLUENT
Help--how to define outlet boundary condition?
Old   May 24, 2012, 17:12
Default Help--how to define outlet boundary condition?
guoji xu
gxu2 is on a distinguished road
Hi,everyone.
I want to simulate 2 D Stokes wave using fluent 13, the result is shown in the picture. In this picture, several waves are good in the first half of flume, but at the second half of the flume, the waves dissipate so rapidly. I don't know why.
I am wondering should I define a pressure profile udf to define the outlet?
Could anybody give some advice? Thanks in advance!
gxu2 is offline   Reply With Quote
Old   May 25, 2012, 02:45
James Willie
jwillie2000 is on a distinguished road
Hi, Can you throw more light on your problem? Like is the flow turbulent? I would assume no? and did you introduce any disturbance at the inlet in the velocity, etc? Jimmy
jwillie2000 is offline   Reply With Quote
Old   May 25, 2012, 09:47
guoji xu
Thank you very much for helping me, my friend!
Actually, the flow is laminar flow, without any turbulent at the inlet velocity profile. the boudary conditions are velocity inlet, bottom--no slipping wall, top--no slipping wall, outlet--out flow.
Should I define a pressure udf for the out flow?
Thank you very much again.
Old   May 25, 2012, 10:52
James Willie
It means u defined a velocity profile at the inlet? Am I getting you right? If yes, then you need to just need to increase the amplitude of the disturbance or flutuation in your velocity profile. The code is probably damping the wave and this is likely numerical. Make sure you do grid dependency test to remove any ambiguity. Jimmy
Old   May 25, 2012, 11:05
guoji xu
Yes, I defined a velociy profile for the velociy inlet. but you could see all the photos I uploaded, which could tell that the inlet wave profile is good, but when propagating, the wave profile changes. It seems my velocity inlet udf is right, maybe it does not need to adjust the disturbance or flutuation in my velociy profile. Do you think so?
Thank you, Jimmy!
Old   May 28, 2012, 06:41
James Willie
Hi, is your profile at the inlet a function? sin or cosine? and if yes, what is the amplitude? I suspect the amplitude is not large enough and so it is being damped? so play with that and see. because you are using the euler euqation, we should not have any damping due to viscous effects. If there is then it is numerical. That is why i am asking about whether you did any grid dependency test? Jimmy
Old   May 28, 2012, 07:33
Daniel Tanner
Daniel Tanner is on a distinguished road
Might be worth trying the pressure outlet boundary condition (instead of the outflow condition). The outflow condition may not be suitable for this application (it assumes fully developed conditions at the outlet).
Daniel Tanner is offline   Reply With Quote
Old   May 28, 2012, 11:16
guoji xu
For my case, VOF method is employed. inlet profile cosists of U-velocity, V-velocity, and volume fraction factor function. it is second Stokes wave, all the function is defined according to Stokes Second Theory. I didn't enlarge the amplitude.
One small question, could you explain what is grid dependency test? you mean try different grid meshing?
Thank you very much! Happy Memorial Day!
Old   May 28, 2012, 11:22
guoji xu
Thank you for your advice. I will try it.
Old   May 28, 2012, 11:23
James Willie
Hi, And thanks for the wishes. About grid dependency test. You have a case where the waves you have in your flow are dissipating quickly than expected. The qauestions is is it physical or non-phsical or numerical? To remove the third case, you try have to do grid dependency test. Like you said you need to vary your mesh resolution till you have no change in your critical variable of interest. It could be the pressure or velocity or temperature in a given section or boundary of your flow. When that happens, you can reliably say that the results you are getting are void of any numerical artifacts and therefore must be due to the physics of the flow. In the case you have right now it would be difficult to say. Good luck! James
Old   May 28, 2012, 11:26
ghost82's Avatar
Daniele
ghost82 will become famous soon enough
Yes, grid dependency test means trying different meshes: start from a coarse mesh and test other finer meshes, and stop when your results don't change to much from a grid to another.
Daniele
EDIT: ok, jwillie was faster
ghost82 is offline   Reply With Quote
Old   May 28, 2012, 11:40
guoji xu
Please excuse me for my little knowledge about "Physical or non-physical", I appreciate your insightful further explaination. Does it bother you too much?
Old   May 28, 2012, 11:41
guoji xu
Daniele
Thank you for your kind-hearted reply. May God bless you!
Old   May 28, 2012, 13:15
James Willie
Hi, Not sure if your question is already answered about physical or non-physical? Physical is whether the phenomenon you are observing or your results can be attributed to physics or reality or not. Some of them are numerical or non-physical...meaning it cannot be attributed to physics and sometimes simply does not hold. Hope it helps. Jimmy
Thread Tools
Trackbacks are On
Wind turbine simulation Saturn CFX 45 February 8, 2016 05:42
How to set the Heat Flux boundary condition at Outlet creddy_trddc CFX 3 September 21, 2011 07:44
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
define boundary condition in just one cell face om1234 Fluent UDF and Scheme Programming 0 June 16, 2010 19:11
