Turbulent viscosity ratio limited to 1.10^5 in boundary layer ingestion
Old   May 27, 2012, 07:31
Default Turbulent viscosity ratio limited to 1.10^5 in boundary layer ingestion
Loic Flouriot
loicflouriot is on a distinguished road
I'm trying to do a simulation about boundary layer ingestion by a S-duct.
I've done my meshing quite well I'll say (4% of cells are below 0,3 quality) and I've no errors and my coarse model I want to run on Fluent is a 1 million cells model.
Then I put my mesh on Fluent and run a 12000 iterations. I chose the k-w SST turbulence model where I've calculated the parameters (turbulent dissipation rate....).
But after a few iterations (200) I've this posted message "turbulent viscosity ratio limited to 1.10^5 in XXX cells"
I've red on the forum to change the turbulence model to the k-epsilon RNG. But the k-w SST model is very well adapted for boundary layer simulate right?
So what other option do I have.
For information I should obtain a strong separation of the boundary layer at the duct bend, and even a back flow in the area close to the inner surface of my duct. My Reynolds number is 6,26*10^6 by unit length
Thanks for your help
loicflouriot is offline   Reply With Quote
turbulent viscosity limited to viscosity ratio Elizabeth FLUENT 13 December 16, 2014 08:57
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
turbulent viscosity limited to viscosity ratio mukkarum FLUENT 3 May 11, 2004 04:05
