Home > Forums > FLUENT
magnetic field in a solid
Old   June 1, 2012, 12:43
Default magnetic field in a solid
emna is on a distinguished road
hello everybody
Actually I have a serious problem with Fluent. I'm modeling a heat source in a magnetic material (solid) which depends on the magnetisation of the material, which is intrinsec property of the material but it doesn't exist in Fluent.
In fact, I have to append to each node the corresponding value of magnetisation. I don't know wether I really could do this with Fluent or not. So my question is how could I append to each node a variable that is not predefined in Fluent.
Pleeeeeeease help me It's reallu urgent!!!!!
emna is offline   Reply With Quote
Old   June 4, 2012, 06:17
Default how to set magnetic field in a solid
Hi everyone :-)
please would you help to solve my problem with Fluent , it's really complicated for me and I need your help so please help help help!!!
Actually as I(ve already mentioned in my previous message I need to simulate heat transfer between a ferromagnteic solid which heats spontaneously when sujected to a magnet and then transfers this heat to a fluid which flows within the pores. The problem is that I have a transient magnetic field that an array of 21 columns and I need to implement it in the solid matrix because the heat source generated within the solid is function of the magnetic field applied. I'm really stuck in this problem and I can't continue my project unless I find a solution to this problem.
I beg you could anyone help I'm really stuck in here ((((
Thread Tools
Trackbacks are On
Setting an external B0_x field in MHD module fferroni FLUENT 6 July 13, 2015 05:29
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
particles in a localized magnetic field Arturo Ortiz FLUENT 1 March 10, 2010 11:26
How to input Magnetic Field values in ESTER Code? Amit Gupta Phoenics 0 September 21, 2006 13:38
computational MHD flows, boundary conditions packer Main CFD Forum 0 March 21, 2006 04:35
