[Sponsors] | |||||
Tamphasana
Rep Power: 3 ![]() |
Hi all,
I am using Eulerian multiphase model with standard k-epsilon turbulence model in gas-liquid phase, udf for drag co-efficient is interpreted successfully but when i start iteration, exactly after 11th iteration it stops showing error as Error: divergence detected in AMG solver:k please help |
Try to reduce Courant number (I am assuming that you are using coupled solver) and also under relaxation factors (for multiphase flow it is really necessary).
#3 | |
Maybe you can try to run a previous calculation without resolving the volume fraction (uncheck it on your Solution Controls) to get an initial field for the multiphase run then. |
Tamphasana
Thanks for your reply
Its running now but its not converging at all especially the gas phase residuals. Mine is pressure based solver and simulating in steady state condition and the following are the boundary conditions: Velocity inlet -velocity of liquid=0 & volume fraction=0 -velocity of gas=0.0025m/sec & volume fraction=1 -diameter of bubble=0.002m please check these conditions as i am little surprised when i mistakenly put gas volume fraction as zero, then the solution was run fine but when i come to know this mistake i changed the value from zero to one, it starts showing problem in convergence. Help is needed |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
| Divergence detected in AMG solver: ads-0 | Patrino | FLUENT | 2 | August 26, 2011 08:28 |
| Error: Divergence detected in AMG solver | siri | FLUENT | 3 | October 21, 2010 14:34 |
| user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
| user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
