Home > Forums > FLUENT
Multiphase Problem Settings
Old   June 2, 2012, 02:08
Default Multiphase Problem Settings
Anniruddha
aniruddha.nasalapurkar is on a distinguished road
I am student doing my project on FLUENT, piston analysis for oil cool gallery application.
I am using VOF model. In that my solution is diverging. Can anyone help me out with the appropriate settings?
My objective is to find out the heat transfer and temperature distribution in the cooling oil gallery.
I have tried with SIMPLE and PISO but still the solution is diverging.
aniruddha.nasalapurkar is offline   Reply With Quote
Old   June 5, 2012, 03:55
Elias Paez
sicfred is on a distinguished road
Is your simulations steady or transient? wich method are you using for VOF (implicit or explicit). If you are in transient and explicit, you should decrease the time step (check the courant number), Piso is a good option, but I do not think it is your problem.
sicfred is offline   Reply With Quote
Old   June 11, 2012, 03:13
Anniruddha
Thank you sir for yor reply.
Avtually i am using Transient, VOF (implicit) settings. Still the solution is getting diverged in the "epsilon".
Please help me for the correct settings.
Old   June 12, 2012, 14:09
Jabba is on a distinguished road
I believe that for transient calculations, the VOF explicit option would be more consistent. Also you should use the "Geo-reconstruct" discretization for the volume fraction. I believe that the "first-order" is the default for the implicit method and this is not good since the interface between the phases is not well defined through this discretization.
I have seen in some works the application of PISO method with "0" value set in the "Skewness correction" option also.
You should also check if your mesh meets the requirements of turbulence model and wall functions in use.
Good luck.
Jabba is offline   Reply With Quote
Old   June 13, 2012, 13:11
Elias Paez
Looks like your problem is more with turbulence model (epsilon divergence) than the VOF, so maybe you should check this part.
As Jabba wrote, the best option of VOF is the explicit with geo-recronstuc, specially when you have to simulate an interface (free-surface), but also can be very unstable and you have to be care of the courant number or use the NITA option. Another option of VOF (no so good as explict-geo) is use the VOF implicit with "modified HRIC" that has a little diffusion in the interface but is more stable
Thread Tools
Trackbacks are On
gas-liquid-liquid multiphase problem suiger CFX 0 December 11, 2010 04:16
Multiphase settings - Interface Compression 100tinela CFX 2 November 18, 2010 19:32
UDF problem in multiphase model Amir Khodabandeh FLUENT 1 March 13, 2009 09:43
Problem of B.C. in Eulerian multiphase model Derek Jing FLUENT 0 May 12, 2002 11:52
CF4 - need advice on setting up multiphase problem Brett Towler CFX 2 August 18, 2000 16:38
