Adding Named Selections
Old   June 4, 2014, 15:33
Default Adding Named Selections
Matty_A is on a distinguished road
I have found if I add the named selections within mesher after the Fluent solver has been opened it causes issues in Fluent. In other words, if I forget to add the named selections before starting Fluent is there any way to add these and then run fluent without starting over in workbench.
Thanks for any insight.
Matty_A is offline   Reply With Quote
Old   June 12, 2014, 06:18
Gonzalo
gfoam is on a distinguished road
Mmm, I don't think you can do this because, when FLUENT starts it checks all the boundaries and if they don't have a explicit name and they are adjacent to each other, FLUENT will sew most of them and will put a default name to each cluster of walls. So, if this doesn't serves to you you will have to do all again in your mesher. Regards
Gonzalo
gfoam is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
only 1 of many named selections not showing up in cfx pre mihirbhagat CFX 2 April 26, 2019 04:56
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Named Selections Issue vitor ANSYS Meshing & Geometry 5 February 7, 2011 14:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
