-   -   OUTPUT form FLUENT (http://www.cfd-online.com/Forums/fluent/102975-output-form-fluent.html)
Chirag2302 June 7, 2012 12:18
OUTPUT form FLUENT
2 Attachment(s)
I need URGENT help for following problem related to output from FLUENT.
I have a two quantity relative pressure and velocity magnitude distribution in computational domain. I have plotted a graph or output for the absolute pressure and velocity with respect to x-axis or longitudinal axis of domain.
Now I want output as power which is defined in my case as:
Power=0.5* P * U * c/s area * Cos (phy)
Where P =relative pressure
U =Velocity magnitude
Value of c/s area and (phy) is known to me and it is constant.
Can any one help me how can i do it in the FLUENT ?????
I have also attached pressure and velocity graph for more clarification.
Similarly, I want the power distribution.
Please, it is URGENT.
Thanking you,
Regards,
CHIRAG FADADU
faudiS8 June 7, 2012 13:25
I do not know how exactly you can do this but I think you've to write a journal and define a new parameter in it. So you can get a report by using this parameter.
Any one has any better idea?I'm eager to know the exact way!
ghost82 June 8, 2012 03:15
I think you can use from fluent a custom field function (?)
http://hpce.iitm.ac.in/website/Manua...g/node1364.htm
Or you can write your own udf to export in a file your results..
Daniele
