unsteady simulation
Old   June 8, 2012, 11:27
Default unsteady simulation
hamid
hamid1 is on a distinguished road
Hi
Is it always correct to use a steady state result as initial condition for unsteady simulation?
thank you so much
hamid1 is offline   Reply With Quote
Old   June 8, 2012, 11:35
ghost82's Avatar
Rick
ghost82 will become famous soon enough
It depends if you want to study your system starting from the steady state...
ghost82 is offline   Reply With Quote
Old   June 8, 2012, 13:39
hamid
thanks for reply, i actually want to have a better convergence rather than starting from steady state, am I allowed to to do that? (i mean starting from steady state)
Old   June 9, 2012, 03:25
ghost82's Avatar
Rick
Describe your system and what you have to study.
Old   June 9, 2012, 09:07
hamid
Hi Daniele
Plz imagine a piping system with three inlets (pressure inlet, amount: P) and one outlet (pressure outlet, amount: -P),
There two phase of flow,
I initialize with pressure for all the domain (amount: P), I simulate with one phase flow in steady state and I take the result as the initial condition for the transient simulation, in transient simulation I introduce the second phase to solve it through VOF method,
P.S. the reason for the bc and initial condition is because I assume the fluids of both phases are initially stationary in the domain, then the suction (outlet pressure -P ) starts to suck the fluids and mainly the second phase.
Thanks for the helps
Old   June 10, 2012, 07:35
ghost82's Avatar
Rick
Hi Amid,
if you initialize the transient simulation with the steady results of the primary phase and in transient simulation you introduce the secondary phase, you are simulating a sort of injection of a secondary phase during a steady flow of the primary phase, and your study starts from this.
If you want to study the flow of two phases both starting from static conditions I think you have not to initialize the transient simulation with steady results.
In addition, If you want to study the transient from static conditions take in mind that inlet pressure value will not be the steady value for t=0 s (for example 6 bar), but probably it will take some time (milliseconds) to reach 6 bar from atmospheric pressure; this can be easily implemented with an udf.
Daniele
Old   June 11, 2012, 03:53
hamid
thanks so much for reply
Adding heat source to chtMultiRegionFoam maddalena OpenFOAM Programming & Development 61 February 17, 2018 08:33
(ASK) can we do y plus adaption in unsteady simulation g-wagon FLUENT 3 March 15, 2012 09:32
Unsteady vs Steady simulation - any difference? Sally Main CFD Forum 16 December 16, 2005 09:15
Procedure to run unsteady simulation? STN Main CFD Forum 2 February 16, 2002 04:37
1D simulation of unsteady gas flows in pipelines Andrew Chernousov Main CFD Forum 1 September 4, 1998 23:42
