domain length
Old   June 7, 2012, 06:23
Default domain length
hamid
hamid1 is on a distinguished road
Hi
How much long should be the length of a pipe with velicity inlet/pressure outlet bc?
what about pressure inlet/pressure outlet,
please also consider a body inside the domain
Thank you
Hamid
hamid1 is offline   Reply With Quote
Old   June 7, 2012, 06:58
delaneyluke is on a distinguished road
If you're asking about the extensions at inlet and outlet then generally use 5D for the inlet extension and 10D for the outlet extension, irrespective of your BC's
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   June 7, 2012, 07:26
hamid
Thanks for reply,
why these extensions should be added? what if the downstream regime dosnt show any change even after 2D ?
Old   June 7, 2012, 08:47
The inlet extension is required so that a fully developed flow enters your pipe domain.
The outlet extension is required to avoid reversed flow at the outlet BC.
You can start with smaller extensions and then increase if the above criteria are not met.
Regards
Luke
Old   June 9, 2012, 04:38
hamid
thanks for reply
Interface between fluid domain and porous domain windhair CFX 6 May 10, 2018 14:26
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 00:42
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Solver error message!!! IoSa CFX 1 September 14, 2006 04:48
