November 18, 2023, 08:22 |
Fluent vs COMSOL
Niranjan
Rep Power: 10 |
.)Ansys Fluent Student version
.)Pressure inlet Pressure outlet boundary condition .)Long 8cm channel with 130 micron diameter with 4 inlet and two outlet at each end. Inlet pressure of 1atm and outlet pressure of 0atm. .)Argon working fluid .) Pressure based solver Image 1 is a result obtained in comsol and it is from a published scientific paper. it has a geometry very close to the one on which I am making an simulation in ansys fluent. doesn't matter what I do I am unable to create the small peaks in density that are near the inlets. I can't understand where i am going wrong. Thank you for your help! |
comsol, fluent |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
COMSOL or Fluent ? | siao fei | FLUENT | 6 | August 30, 2011 06:55 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
COMSOL or Fluent ? | siao fei | Main CFD Forum | 0 | May 16, 2006 15:07 |
