-   -   Please help me!!!!!!! analysis of a semi salvage rotating cylinder in a fluid (http://www.cfd-online.com/Forums/fluent/103194-please-help-me-analysis-semi-salvage-rotating-cylinder-fluid.html)
adambarfi June 13, 2012 06:44
hi everybody
Can I analyze a semi salvage rotating cylinder that placed in a fluid by Fluent?!?!?
the half of cylinder is in water and the other half is in air and cylinder is rotating with a constant angular velocity.
Is it true that I must use multiphase and dynamic meshes?
Please help me.
ghost82 June 13, 2012 12:39
I think you can use multiphase model and assign an angular velocity to the wall of the cylinder.
I think there's no need for dynamic mesh.
Daniele
adambarfi June 14, 2012 01:53
Daniele
Thank you Daniele,
But I need the shape of water while the cylinder is rotating, does Fluent give me it without using dynamic mesh? actually I have two fluid zone: water and the air above it. do i need to consider the air above the water?
again thank you
Mostafa
