run parallel distributed in cluster
Old   June 18, 2012, 17:41
Default run parallel distributed in cluster
Fer Villa
fevi84 is on a distinguished road
Hi all,
I want run my fluent case in a cluster using several nodes and processors (I'm using Torque as manager in the cluster). The PBS journal is:
#PBS -N LSVOFaxi
#PBS -m ae
#PBS -M user@domain.com
#PBS -l nodes=2n=4 (the face are two point, I don't know why appears it)
FLUENT_PATH=/cluster/apps/ansys_inc/v140/fluent/bin
cd ${PBS_O_WORKDIR}
$FLUENT_PATH/fluent 2ddp -g -ssh -pinfiniband -t8 -cnf=/home/Documents/LSVOFaxi/fluenthostsn2p4 -i LSVOFaxi.txt > LSVOFaxi.log
The hosts file (fluenthostsn2p4) is:
r1i0n2
r1i0n2
r1i0n2
r1i0n2
r1i0n15
r1i0n15
r1i0n15
r1i0n15
<white line>
But this not worked.
I think that the error is in the following line command, but I don't know:
If anyone know solve it, please help me.
Thank you.
When I ran parallel local, with 1 node and 4 processors, using the following PBS journal, this worked.
#PBS -N LSVOFaxi
#PBS -m ae
#PBS -l nodes=1pn=4 (the face are two point, I don't know why appears it)
cd ${PBS_O_WORKDIR}
$FLUENT_PATH/fluent 2ddp -g -t4 < LSVOFaxi.txt > LSVOFaxi.log
fevi84 is offline   Reply With Quote
SimpleFoam run in Parallel jayrup OpenFOAM 9 July 26, 2019 00:00
Problems about distributed parallel runs vkrastev OpenFOAM Running, Solving & CFD 10 November 11, 2012 09:22
Can't run in parallel JulytoNovember OpenFOAM Running, Solving & CFD 2 March 31, 2012 09:28
poor performance at massive parallel run using SGI cluster matthias OpenFOAM Running, Solving & CFD 8 October 21, 2011 08:24
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 16:36
