Writing data file for specified variables
Old   June 17, 2012, 13:58
Question Writing data file for specified variables
Soroush
SH_P is on a distinguished road
Hello friends,
I am doing a transient simulation on a large mesh resulting in large data files. Is there any way to reduce data files size.
The only quantities that I need are velocity and pressure, However fluent write many others which are of no use for me and I could not dis-select the default variables in data file quantities window.
Please help me. my thesis depends on this simulation an I really can not handle such huge amount of data.
Thanks in advance.
SH_P is offline   Reply With Quote
Old   June 18, 2012, 13:20
Soroush
Someone told me that there must be a way to write a UDF in order to specify variables to write. Does anyone know how to do this? I want my .dat file be connected to .cas file with less variable.
SO the question is how to write a output file (with UDF maybe) with the same format as the original fluent data file which is connected to the corresponding case file ?
Thanks.
Old   June 19, 2012, 03:21
Max
coglione is on a distinguished road
Maybe writing an interpolation-file (file/interpolate) will do the trick for you. Test it for a given solution-time and if it works fine (check if your velocity and pressure fields are the same as in the corresponding .dat) use a macro to save an interpolation file at specified intervals during the simulation.
cheers
coglione is offline   Reply With Quote
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
