-   -   plot pressure vs crank angle (http://www.cfd-online.com/Forums/fluent/103335-plot-pressure-vs-crank-angle.html)
tdbbz June 17, 2012 20:08
Hi everyone,
How to plot pressure vs crank angle? Only three options for x-axis are available in monitor.
thx.
Mnzki June 19, 2012 01:29
I think in the "Plot" area, you could choose what variable to represent for each axis, I'll check it for you later.
Another option is to output the pressure vs crankangle data and draw the curve in Excel or other softwares. I believe this functionality is somewhere under the "Export" tab. Again, if you need I can check it for you later as I do not have access to Fluent right now.
tdbbz June 19, 2012 08:57
Mnzki, thanks a lot for your reply. I will follow what you provided.
