June 19, 2012, 15:45 |
fluent mpi
nikos
Rep Power: 15 |
Hello guys,
I was wondering which are the required applications for executing fluent in parallel? I use linux, and more specifically fedora 16 version. Is it needed any specified version of mpi and where is it advisable to be installed? I'm asking this becasuse i use mpi through PETSc which isn't installed in a common folder for example usr/ ... Thanks in advance for your help. |
July 5, 2012, 17:28 |
Casey
Rep Power: 16 |
I have found that fluent runs pretty well in parallel out of the box as long as you have the correct licenses. You can not run a simulation on more than 4 processors with a serial license (you will be using 4 licenses). There is lots of stuff around the fluent website/documentation about what to do about compilers. With RHEL 6, fluent in parallel just ran out of the box for me. |
Display Modes | |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
Error in reading Fluent 13 case file in fluent 12 | apurv | FLUENT | 2 | July 12, 2013 08:46 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 03:44 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 03:57 |
