Mass Addition
Old   June 25, 2012, 11:25
Exclamation Mass Addition
Aswin
jcaswin is on a distinguished road
I am having a geometry that resembles a normal rectangle. The walls; upper wall and the lower walls (which are the walls running along the length of the rectangle) are to given with the condition of adding mass to it. How is it possible in Fluent? Or should i opt for some other Code? And if it's possible in Fluent what should i do to apply it?
jcaswin is offline   Reply With Quote
Old   June 26, 2012, 07:55
eng_s_sadeghi's Avatar
eng_s_sadeghi is on a distinguished road
Source terms are just available in volumes. But you can use boundary conditions at faces for importing a mass to your domain.
Saeed Sadeghi
Ansys Fluent CFD Consultant
eng_s_sadeghi is offline   Reply With Quote
Old   June 26, 2012, 14:01
Aswin
Thanks for your consideration and reply sir.
Old   June 26, 2012, 14:03
Aswin
But I am dealing with only the 2D geometry and not 3D. In that case where can I find the options for the Mass Addition or I am looking for the Moving Boundary itself.
Old   June 27, 2012, 00:35
You can just use boundary condition for importing mass the your domain. Source terms are used just for inside of the domain not the faces around.
Saeed Sadeghi
mass fraction of species Lilly FLUENT 5 March 13, 2022 17:52
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
UDF for heat addition and mass addition Srikanth FLUENT 2 September 20, 2006 19:12
