Home > Forums > FLUENT
Lift Coefficient Problems
Old   June 27, 2012, 15:45
Default Lift Coefficient Problems
Hannah Mac
hannah72206 is on a distinguished road
I'm running Fluent on a simple UAV design and I'm trying to get a lift coefficient curve. I have a set of design points that run from an angle of attack of 0 to 25 degrees. I get a max lift coefficient around 16 degrees. It goes down at 18 degrees. Then goes back up when it gets to 20 degrees! What is going on?
I've tried both steady state and transient with no real difference.
hannah72206 is offline   Reply With Quote
Old   June 30, 2012, 03:36
cfd seeker is on a distinguished road
Running steady state solver is out of question at such a high angle of attack because there is lot of flow separation at these angle of attacks but the problem you are telling looks quite strange. Give it a try by changing your time step and then let me know what happens.
Regards
cfd seeker is offline   Reply With Quote
Old   July 3, 2012, 12:02
Hannah Mac
It turned out to be as simple as a mesh problem in that the mesh wasn't fine enough around the UAV. The wind tunnel was so large that even when the cells looked small, it wasn't enough. I have fixed it now, and I'm getting a beautiful coefficient curve even with steady state. (I'm not going too far past the stall angle) Thank you!
Thread Tools
Trackbacks are On
Lift coefficient in Eulerian multiphase model hennas FLUENT 1 July 4, 2011 16:50
turbulence models and lift coefficient for naca 0021 Nick R CFX 5 March 8, 2011 03:21
Coefficient DRAG and LIFT - Cylinder 3D Jwolf CFX 11 February 4, 2010 06:08
drag and lift coefficient No CD-adapco 5 July 13, 2004 10:21
Help needed - lift coefficient on front/rear axle Jan Jagrik FLUENT 0 September 21, 2000 10:21
