Turbine simulation
Old   June 30, 2012, 20:25
Smile Turbine simulation
Sarah4
sarah4 is on a distinguished road
I saw some of the posts sharing experences doing the Phase vi turbine simulation.Some people are very successful on this. Currently i am doing the same thing to learn cfd. It is greatful if you could give me some suggestions:
1. What is the first height of your mesh to get an relatively accurate result? Say height of 0.01mm, this kind of mesh always resulted in bad cells. Can we change the sharp trailing edge to blunt trailing edge as the real blade?
2. When using two domains (one is rotational and the other one is stational) to simulate the flow around a turbine, should we define the flow rotational direction the same as the blade rotating direction (say "+Y")(turbine drive flow), or we define "-Y" for the flow? I got two different results but both positive torque. ...
Thanks in advance for your reply.
sarah4 is offline   Reply With Quote
Simulation of Wind Turbine with OpenFoam be_inspired OpenFOAM 52 September 6, 2018 10:33
Verifying results for a wind turbine blade simulation in ANSYS CFX Joystix CFX 3 April 27, 2012 17:52
radial turbine blade simulation with dynamic mesh 6dof(fluent) mamyjooooon FLUENT 0 April 7, 2011 14:28
wind turbine simulation moca CFX 1 July 25, 2009 06:48
cfx turbine simulation mehrdadeng CFX 0 March 31, 2009 05:08
