July 6, 2012, 23:28 |
Solution Methods in Fluent
vikas
Which solution methods should i use for simulating Pump sump model ?
I have attached images for your reference, please have a look. By solution method i mean, for pressure "Second order", Second order upwind.... |
July 9, 2012, 09:31 |
Philipp
Rep Power: 26 |
Your question cannot be answered in general. Specially, when you give so few information about your setup.
Normally, the higher the computational order, the better are your results, but this is not true for every possible case. If you don't do any special high accuracy calculations - just try the defaults. You can also try whether your grid is stable when using 2nd order or not. This should (again: usually) be much better than the defaults. |
CFL Condition | Matt Umbel | Main CFD Forum | 19 | June 30, 2020 08:20 |
define a water-salt solution in fluent | arashmarahel180 | FLUENT | 7 | February 13, 2019 00:26 |
Initial solution fluent | fevi84 | Fluent UDF and Scheme Programming | 1 | June 23, 2012 12:10 |
intializing data in fluent from an available solution( from an opensource code) | ayannath23 | FLUENT | 1 | December 21, 2010 12:54 |
Fluent Solution Residuals | RC | FLUENT | 2 | September 30, 2003 02:34 |
