Home > Forums > FLUENT
Fluent 12.1 Journal File
Old   July 10, 2012, 08:54
Default Fluent 12.1 Journal File
CFD-1987
CFD-1987 is on a distinguished road
Hi to everyone,
I am having a problem with Fluent 12.1 running a Journal I've written. Firstly, although i am putting the cas file and journal on the desktop when i open Fluent to run the journal file it is giving me an error that it is not finding the cas file. Secondly, I would like it to give me the velocity magnitude contours but it is giving me only the residual plots and in grey scale not color as i write in the command. I 've written the commands i used in the journal file for your consideration....maybe i am doing something wrong so i would appreciate it if someone could help me!
Journal File:
/file/read-case fluent1
/file/auto-save/data-frequency/1000
/file/auto-save/retain-most-recent-files yes
/file/auto-save/max-files/1
/solve/iterate/10000
/display/contours velocity-magnitude
/display/contours/filled-contours yes
/display/contours/global-range yes
/display/color-mode/color
/display/dpi
/display/driver/jpeg
/display/save-picture velocity1
/file/write-case-data fluent1_end
CFD-1987 is offline   Reply With Quote
Old   July 13, 2012, 05:16
Marion
Marion is on a distinguished road
I am confused: if it is not opening your case, how can it run??
You have to put your journal and case files in the directory where you start Fluent otherwise Fluent isn't going to find the case.
Marion.
Marion is offline   Reply With Quote
Thread Tools
Trackbacks are On
swak4Foam-groovyBC build problem zxj160 OpenFOAM 18 July 30, 2013 13:14
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
