How do I set a boundary at a hole inside the tube
Old   July 16, 2012, 03:22
Unhappy How do I set a boundary at a hole inside the tube
Theerawat
Theerawat is on a distinguished road
Hi guys, My geometry is a tube with water inside and I want to feed air at the center of that tube by using a smaller tube which is inserted to the center of the bigger tube. So I built the hole through to the bigger piper. The problem is I cannot set the boundary at the outlet of the smaller tube where the air go out. So, What should I do to set up the boundary at inside tube (at the blue circle of the picture)
Thank you those who can help me
Theerawat is offline   Reply With Quote
Old   July 16, 2012, 04:16
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Which version of DM do You use? I think in version 14 this is - finally - pretty easy:
Create a cyllinder that cuts your large tube in such a way, that it produces exactly the boundary you want. Use "frozen body" for each body!
Then, use the boolean operation. Now, in "Operation" choose "Imprint Faces"
Target body is your main pipe, tool body is the small (new) cyllinder. Choose "no" in the last option to destroy the tool body.
Here we go!
RodriguezFatz is offline   Reply With Quote
Old   July 16, 2012, 04:20
Theerawat
I use solid work to draw this geometry so do you know what should I do
Old   July 16, 2012, 06:01
Theerawat
OK I try to do what you told me. Do the frozen body means "freeze". I choose freeze but cannot click on boolean. could you tell me more? And if I import the parasolid from solidwork, what should I do ?
Thank you very much
Old   July 16, 2012, 07:07
Philipp
Thank you very much
Frozen, freeze... whatever I have a different language file in DM...
I have no clue about solidwork.
In DM, if you create two bodies that intersect and are not frozen, they automaticaly merge to a single body. So in your case you don't want that, since you want to work with them (all that boolean operation stuff). If you create your cutting body, be sure you choose a frozen body.
After creating the body you must apply a boolean operation (create -> boolean). Then try the steps from my other post.
How to set a oblique incidence wave Boundary shiw FLOW-3D 2 March 6, 2011 19:15
set up boundary ritmat FLUENT 5 July 24, 2007 03:38
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
