different answers
Old   July 18, 2012, 02:00
Default different answers
Mindaugas
newminde is on a distinguished road
Hi everyone, I have a problem with answers.
I'm doing tutorial https://confluence.cornell.edu/displ...+Specification
Velocity inlet 1m/s, RE=20.
If I open Ansys fluent and read a mesh, the result of drag coffiecient is 2.0427
If I open ansys workbanch and do the same the result is 2.14..
How is ot possible. Units SI.
newminde is offline   Reply With Quote
Old   July 18, 2012, 04:35
Marion
Marion is on a distinguished road
Are you sure the settings in Fluent are the same? For example double precision vs. single precision? (I've had that recently!)
Marion.
Marion is offline   Reply With Quote
Old   July 18, 2012, 04:59
cfd seeker is on a distinguished road
there is not too much difference between 2.04 and 2.14 values that you should worry about. But if at all you need an answer to your question it can be difference between the schemes which you are using for both simulations e.g solver settings, density based or pressure based, single or double precision and even reference values etc
cfd seeker is offline   Reply With Quote
Old   July 18, 2012, 06:04
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Do you mean that there is a difference when you do the POST-PROCESSING of the Fluent-calculation in Fluent directly and in the CFX-like result component in the workbench?
Now that would be a serious issue, although it is not surprising.
If you mean that the results are different when tha SIMULATION is conducted in Fluent and in CFX, this is nothing to worry about.
flotus1 is offline   Reply With Quote
Boss asking for dishonest answers Torque_Converter Main CFD Forum 15 May 30, 2012 19:34
need questions and answers on marine CFD entry level(M.Sc) ucsmoothsail Main CFD Forum 0 December 30, 2011 10:53
inconsistent answers Robreid FLUENT 0 May 27, 2011 16:15
[TGrid] Simple Question (Simple Answers?): Edge Length adjustment for tet mesh booz ANSYS Meshing & Geometry 0 August 29, 2010 12:39
Different answers heydari FLUENT 4 February 25, 2003 04:04
