microchannel's modeling
hi
i want to modelling a micro channel , micro channel is solid and silicon , fluid that flows through it is nano fluid , my problem is where i choose silicon as a solid in fluent (material's section) my materials list just changes in to aluminum !!!! please some body help me im a beginner in cfd |
Are you sure there is solid silicon in the materials database? In my version of Fluent (12.1) silison is only defined as a fluid. In the create/edit materials panel if Ichoose "Solid" from he drop down menu (upper right corner) I cannot see silicon. There is solid silicon in the fluid database though - but I guess it can only be defined as fluid, and cannot replace Aluminum as a solid. Marion. |
thanks marion . the version of my fluent is 6.3 . so you mean that i should choose silicon as a fluid ? but once i solved the problem with choosing silicon as a fluid and my teacher said its wrong
No - I jut meant that you cannot choose Silicon in the solids as it is not there... Have you tried creating your own solid using the silicon properties?
So u mean ,i crate a new material with solid silicon properties but choose the solid option in materials menu?
Yes! That's what I mean.
Thanks so much Marion.
