-   -   journal file:write-case-data (http://www.cfd-online.com/Forums/fluent/104897-journal-file-write-case-data.html)
Lilly July 18, 2012 06:11
Dear all,
I want to start a transient Fluent-simulation as a batch job and therefore wrote a journal file.
/file/read-case-data/ D:\TestFile.cas
/solve/set/time-step 0.01
/q
/solve/dual-time-iterate 50 200
/q
/file/write-case-data/ D:\TestFileComplete.cas
But for any reason I cannot make fluent save the final case and data files as denoted in the last lines of my journal file. I don't get any error message, but fluent just stops after the calculation. I already tried a lot of variations of the last lines.
Does anybody have an idea?
Thanks a million for all ideas and help!
Lilly
Marion July 18, 2012 06:46
It won't help you a lot but I just tried your last command line in Fluent and it worked fine for me.
Are you sure you have the writing rights on your D:\ directory?
Marion.
Andrew.Coughtrie July 18, 2012 10:14
don't bother telling fluent where to put the file, it will put it in the working directory if you just give it a file name, also needs quotes, this should work (see below), if not then try making your working directory something other than the root of D:\ say D:\Test\ root permissions can sometimes cause problems.
/file/write-case-data "solution.cas.gz"
Andy
manuels September 9, 2012 02:51
I also write a journal file. It can read the case- and the dat-data but when it wants to initialize the calculation it stops. Can someone help me?
; Read case file
rc propellerviskosimeterFluent.cas
rd propellerviskosimeterFluent.dat
; Initialize the solution
;/solve/initialize/initialize-flow
; Calculate 50 iterations
it 50
; Write data file
wd example50.dat
; Calculate another 50 iterations
it 50
; Write another data file
wd example100.dat
; Exit FLUENT
exit
yes
Greetings
Bionico September 10, 2012 02:14
Hi manuels,
in the journal you posted here I see the semicolon before the command:
maybe you have forgotten to cancel it :)
