Home > Forums > FLUENT
Abuout turbulent viscosity
Old   July 19, 2012, 02:46
Smile Abuout turbulent viscosity
Zhe Lu
albatross is on a distinguished road
Hi everyone:
I'm calculating a case with an airfoil flying in ground effect. The height, h/c, is 0.01, and Re is about 2e7. Everything looks alright, except that the turbulent viscosity is over the default limit of 1e5 in some cells(red ones in the picture below).
And there are no similar phenomena in other fields like turbulent kinetic energy, velocity, etc. So, anybody has any suggestions? Thanks in advance!
albatross is offline   Reply With Quote
Old   July 19, 2012, 02:52
Alex S.
flotus1 will become famous soon enough
I have some questions about your setup.
The tiny little spot at the bottom center of the image is the airfoil, right?
What are the boundary conditions for your simulation and where are they applied?
I am especially curious about the boundary condition for the "floor" and the inlet.
Could you show the mesh you used in the same view as the contour plot of the turbulent viscosity ratio is taken?
flotus1 is offline   Reply With Quote
Old   July 19, 2012, 07:21
Zhe Lu
The little spot is the airfoil. Other than the airfoil, there are 4 boundaries: inlet, outlet, "floor" and "ceiling". I set the floor as a moving wall with the same velocity as the flow and set inlet as velocity inlet. The outlet is pressure outlet and the ceiling is symmetric. Plus, the turbulence model is realizable k-e with enhanced wall treatment. The picture I uploaded might be a little bit misleading, actually there is some distance between the inlet and the red cells, so here is a new one.
Old   July 19, 2012, 07:22
Zhe Lu
This thread doesn't make any sense, but I don't know how to delete it...
Old   July 19, 2012, 07:41
Alex S.
The boundary conditions are ok.
It seems like the viscosity ratio is high in cells with a high aspect ratio.
Am I right assuming that the cells near the inlet have the same height as the cells in the boundary layer of the airfoil because of the block structure of the grid?
I know this will result in a very high cell count, but try to obtain better aspect ratios in the cells near the inlet and the outlet with smaller cells in the streamwise direction.
Old   July 20, 2012, 04:17
Zhe Lu
You're right about the high aspect ratio cells. I was trying to obtain fine enough mesh near the airfoil and the ground, and the aspect ratio of the cells near the inlet reaches 1e6... But the red cells are not those with the highest aspect ratio. Anyway, I will follow your suggestion and have a try, thank you!
Thread Tools
Trackbacks are On
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 10:02
Turbulent viscosity and shear rate shib FLUENT 0 June 22, 2010 12:44
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 3 February 11, 2010 04:53
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
