microchannel's modeling
Old   July 17, 2012, 12:20
Question microchannel's modeling
raha
raha is on a distinguished road
hi
i want to modelling a micro channel , micro channel is solid and silicon , fluid that flows through it is nano fluid ,
my problem is where i choose silicon as a solid in fluent (material's section) my materials list just changes in to aluminum !!!!
please some body help me im a beginner in cfd
raha is offline   Reply With Quote
Old   July 18, 2012, 04:43
Marion
Marion is on a distinguished road
Are you sure there is solid silicon in the materials database? In my version of Fluent (12.1) silison is only defined as a fluid.
In the create/edit materials panel if Ichoose "Solid" from he drop down menu (upper right corner) I cannot see silicon.
There is solid silicon in the fluid database though - but I guess it can only be defined as fluid, and cannot replace Aluminum as a solid.
Marion.
Marion is offline   Reply With Quote
Old   July 19, 2012, 08:09
Post
raha
thanks marion . the version of my fluent is 6.3 . so you mean that i should choose silicon as a fluid ? but once i solved the problem with choosing silicon as a fluid and my teacher said its wrong
Old   July 19, 2012, 08:53
Marion
No - I jut meant that you cannot choose Silicon in the solids as it is not there... Have you tried creating your own solid using the silicon properties?
Old   July 19, 2012, 09:04
Post
raha
So u mean ,i crate a new material with solid silicon properties but choose the solid option in materials menu?
Old   July 19, 2012, 09:07
Marion
Yes! That's what I mean.
Old   July 19, 2012, 09:14
Thumbs up
raha
Thanks so much Marion.
micro channel, two phase flow
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
Solid Modeling Chris Main CFD Forum 10 July 2, 2002 07:12
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
Extrusion Modeling Elliot Schwartz Main CFD Forum 1 September 11, 1998 19:08
