problem of semi-transperant wall
Old   July 20, 2012, 00:48
Default problem of semi-transperant wall
Wei Kai CHEN
cweikai is on a distinguished road
Bonjour,
I'm recently running the simulation of solar radiation problem. There's no other heat resource but the sun light, and I've set a semi-transparent wall facing to the sun, but when I was going to run the circulation I got the warning shown as follow
Theoretical Maximum:
Sun Direction Vector: X: 0.0450431, Y: 0.304243, Z: -0.951529
Sunshine Fraction: 1
Direct Normal Solar Irradiation [W/m^2]: 1423
Warning: The neighboring cell threads (13 and 10) of semi-transparent wall zone 15 are not fluid.
This problem MUST be fixed before proceeding!
any suggestion would be helpful
thanks
Weikai CHEN
cweikai is offline   Reply With Quote
Old   July 20, 2012, 01:37
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
I haven't run into this error yet, but if I were you I would do what the error message tells me.
Put a fluid next to the semi-transparent wall.
flotus1 is offline   Reply With Quote
Old   July 20, 2012, 01:48
Wei Kai CHEN
thanks
I've set the air adjacent to the semi transparent wall
just wondering why the warning was shown
Problem with wall function gregjunqua OpenFOAM 5 August 25, 2011 23:32
Two Sided wall Problem Mk1987 ANSYS Meshing & Geometry 0 March 26, 2010 13:37
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 05:36
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
moving wall BC problem Sourabh Main CFD Forum 1 August 8, 2006 07:47
