-   -   180 Degree Bend Duct Flow in FLUENT (http://www.cfd-online.com/Forums/fluent/105212-180-degree-bend-duct-flow-fluent.html)
John222 July 25, 2012 08:49
I'm simulating a 2D U-bend duct using FLUENT.
Properties from experimental case are;
U= 31.1m/s.
Mach= 0.1.
Operating Pressure= 12atm.
Re=10^6.
What are the boundary conditions at inlet and outlet?
:p
flotus1 July 25, 2012 09:10
If you don't know where and how the values were measured, I would try a velocity inlet with a bulk velocity of U and a pressure outlet at the operating pressure.
John222 July 25, 2012 09:11
So you mean at inlet I should have 31.1 with 0 pressure, and at outlet 12atm operating pressure?
flotus1 July 25, 2012 10:23
As far as I know you do not need to specify a value for pressure at a velocity inlet.
The pressure at the inlet will be a result of your simulation.
