July 30, 2012, 06:40 |
Issue with wall created by moving mesh
Alex
Rep Power: 13 |
I am trying to perform a 2D model of a VAWT. I have a moving mesh around the blades, a static mesh elsewhere, and an interface between the two meshes. After a flow time of approx. 2.2 seconds I am seeing some strange behaviour (see first screenshot). The inflowing air does not appear to be entering the moving mesh. From a closer inspection it appears that the wall which have been created from the interface are forcing the air to move with them (2nd screenshot). These walls are no-slip (by default) but I was under the impression that I did not have to modify walls which are created by FLUENT from an interface. Another analysis with only a different tip speed ratio does not have the same problem. Can anyone tell me what is going from here? Thanks Alex |
July 30, 2012, 12:05 |
Stuart Buckingham
Rep Power: 25 |
July 30, 2012, 12:24 |
Alex
Rep Power: 13 |
I have created an interface between the two zones. FLUENT created two no slip walls as part of the interface creation though
Display Modes | |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
