boundary condition in inducer
Old   July 28, 2012, 03:03
Post boundary condition in inducer
khalil
thousand is on a distinguished road
hi
i'm trying to model a inducer in rated flow of pump
suction pressure is known but pressure in outlet of inducer and inlet to impller is unknown
i try with pressure inlet and pressure outlet(i guess a pressure) and compute the flow rate and compare it with nominal flow rate but i have not enough time to iterate with wide guess pressures.
Am I putting the right boundary condition at the outlet or inlet?
can you give me a better strategy?
tanks alot
thousand is offline   Reply With Quote
Old   July 28, 2012, 06:34
eng_s_sadeghi's Avatar
eng_s_sadeghi is on a distinguished road
This is not possible, you should know the outlet pressure. Also I think it is better to use mass flow inlet for better converges. I mean put the real mass flow in the inlet and the outlet pressure, after solving check if the inlet pressure is correct or know.
Saeed Sadeghi
Ansys Fluent CFD Consultant
eng_s_sadeghi is offline   Reply With Quote
Old   July 29, 2012, 16:32
Smile
khalil
thanks a lot
i try with increase 3m in head in inducer but flow rate was very far from my desire flow rate but range of pressure was very far from cavitation
i too simulate in free cavitation , with pressure inlet in inlet and mass flow rate in outlet increase in head is about 24m and is mistake beacuse maximum incrase head must be 5% total head (9 m).
there is a problem that inducer act as axial pump and his flow rate is independet from head
now this act for checking flow rate in various pressure or checking pressure in various flow rate is true?
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 02:37
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
