Home > Forums > FLUENT
Issue with wall created by moving mesh
Old   July 30, 2012, 06:40
Question Issue with wall created by moving mesh
Alex
boshank20 is on a distinguished road
I am trying to perform a 2D model of a VAWT. I have a moving mesh around the blades, a static mesh elsewhere, and an interface between the two meshes.
After a flow time of approx. 2.2 seconds I am seeing some strange behaviour (see first screenshot). The inflowing air does not appear to be entering the moving mesh.
From a closer inspection it appears that the wall which have been created from the interface are forcing the air to move with them (2nd screenshot). These walls are no-slip (by default) but I was under the impression that I did not have to modify walls which are created by FLUENT from an interface. Another analysis with only a different tip speed ratio does not have the same problem.
Can anyone tell me what is going from here?
Thanks
Alex
boshank20 is offline   Reply With Quote
Old   July 30, 2012, 12:05
Stuart Buckingham
stuart23 will become famous soon enough
Are they No-Slip walls or have you defined an interface between the two zones?
http://bc247.wordpress.com
stuart23 is offline   Reply With Quote
Old   July 30, 2012, 12:24
Alex
I have created an interface between the two zones. FLUENT created two no slip walls as part of the interface creation though
Thread Tools
Trackbacks are On
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Layers:problem with curvature giulio.topazio OpenFOAM Native Meshers: snappyHexMesh and Others 10 August 22, 2012 09:03
How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
