is this possible in fluent...
Old   July 11, 2008, 12:33
Default is this possible in fluent...
dhileep
i am a beginer in fluent. i have understood some basic physics by solving some steady stat problems in fluent to get a feel of the software.now i like totry some real time problems. i like to know whether the following work can be done in fluent. i am having a overhead tank which is full. there is a opening at the bottom of the tank. can i simulate and see the fall in the water level in the tank. please some body help me.
Old   July 11, 2008, 12:36
Default Re: is this possible in fluent...
umesh javiya
Use VOF multiphase model....
see Fluent User manual.... and also see the VOF tutorial.....it will help u lot.....
Old   July 12, 2008, 03:36
ravi kumar
hi ,
u can do it.. its not a big problem..
u can use VOF method in multi phase.. and unstrady option. give gravity effects also..
Old   July 15, 2008, 16:35
dhileep
i have solved that VOF tutorial in the fluent. but i am getting the error message as
Error:Floating point error:invalid number
Error object) what may be the reason for this.
also i am having some doubts in that,
1. i was not able to understand the meaning of defining a custom field function as 3* radial component.
2. also not able to understand the meaning of patching that custom field function to the water.
--can you please refer the tutorial and clear those doubts
Old   October 19, 2010, 05:13
Default floating point error!! help!!
kanthores
kanthores is on a distinguished road
I'm using Fluent to modelling a PEM fuel cell. I do it according to the manual but when i do iteration, i get the error message:
error:Floating point error:invalid number
please any one can help me for this.
thanks
kanthores is offline   Reply With Quote
Old   August 7, 2012, 07:53
Default happen History repeat it self
Emad
elemad1987 is on a distinguished road
Send a message via Skype™ to elemad1987
guess what happenHistory repeat it self.
I have the same problem as you
I am using the Fluent 14 and I want to simulate a PEM fuel cell.
The only tutorial of PEM fuel cell of Fluent is from 6.3 version.
I use it to Fluent 14 and I follow the steps but the results does not the same, also some data and parameters are different.
Anybody know if the tutorial of 6.3 Fluent is working to Fluent 14 too?
I think now you had finish your thesis peacefully.
Can you help me to overcome my problems.
or send me your cas files.
Thank you
Emad G.
elemad1987@gmail.com
elemad1987 is offline   Reply With Quote
Fluent in Linux vs. Fluent in Windows Melih FLUENT 6 November 16, 2014 09:39
Fluent/Unix vs. Fluent/Windows sjjaber FLUENT 10 January 5, 2005 16:58
Running FLUENT 6.0 sims. on FLUENT 6.1 ozgur FLUENT 2 April 2, 2004 13:23
