TUI for zone fixed value
Old   August 6, 2012, 13:43
Default TUI for zone fixed value
Negin Nazarian
nenazarian is on a distinguished road
Hi
Does anyone know how to fix only one value in cell zone condition?
I used this command:
define/boundary-conditions/fluid/(zone name)/fixed-value
but the problem is you cant only fix temperature and leave the rest unchanged. enabling "fixed value" option will set velocity and other parameters as fixed too...
any suggestion?
Cheers
Negin
nenazarian is offline   Reply With Quote
Old   August 6, 2012, 15:01
np
ravipati is on a distinguished road
You can turn on the fixed value in the cellzone conditions GUI. Then enter the value for the temperature and keep the remaining parameters as none.
ravipati is offline   Reply With Quote
Old   August 6, 2012, 15:24
Negin Nazarian
I am doing that right now but the whole point is to change it to TUI.
TUI command doesnt give u the "none" option in the list.
Old   August 6, 2012, 16:41
np
You can do it this way:
Use Profile for X Velocity (m/s) fixed? [yes]
Use UDF Profile for X Velocity (m/s) fixed? [yes] no
do this for 3 components and specify temperature as you wish.
Old   August 6, 2012, 18:24
Negin Nazarian
Thank you for your response
you are right.I tried this before but then it gives some error about the "profile" in initializing .. do you know how I can fix that too?
I appreciate your help
Cheers
Negin
Old   August 6, 2012, 18:42
Negin Nazarian
This is what I get for initializing:
/solve/initialize/hyb-initialization
Error: interpolate_profile_field: thread 23: profile "" does not exist.
Old   August 7, 2012, 14:13
Negin Nazarian
I just got back from ANSYS
"This is a bug in FLUENT14.0 and is fixed in our next version FLUENT14.5, which will be released during Nov. time. .."
TUI Commands from GUI? Carlos FLUENT 6 May 22, 2013 18:05
Fixed mean temperature boundary condition for developing flow mohsen cheraghi OpenFOAM 2 July 24, 2011 13:06
Fan Boundary Condition OR Fixed Values or Source Terms SolarX FLUENT 1 June 9, 2011 04:13
Define animate using TUI Zurlugh FLUENT 1 July 24, 2008 08:55
Has the pressure to be fixed at one node? Steve Song Main CFD Forum 5 February 9, 2003 13:14
