Fluent Error message when importing mesh
Old   August 8, 2012, 06:49
Default Fluent Error message when importing mesh
Amarender
amarendernag is on a distinguished road
I am new to Fluent software. I am using Ansys 13.
When I am importing a mesh to Fluent, it is showing the following message.
785292 nodes, binary.
34721 nodes, binary.
9135883 mixed interior faces, zone 1, binary.
6737 triangular wall faces, zone 5, binary.
563 mixed velocity-inlet faces, zone 6, binary.
515 mixed pressure-outlet faces, zone 7, binary.
41460 mixed symmetry faces, zone 8, binary.
17763 triangular wall faces, zone 9, binary.
4554076 mixed cells, zone 2, binary.
Building...
mesh
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc face-dr1, size 109630596, t 1, myid 1000000.
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
Preparing mesh for display...
Done.
Done.
Reading Settings file C:\Users\amarendernag\Documents\ansysfiles\car_fil es\dp0\FFF\Fluent\FFF.set..
Error: SET-CDR!: invalid argument [1]: wrong type [not a pair]
Error Object: #f
Setting Post Processing and Surfaces information ...
Error: lvectorlength: wta(1)
Error Object: ()
Please help me to overcome this problem.
amarendernag is offline   Reply With Quote
Old   August 9, 2012, 10:49
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
It seems like you are running out of memory. Could that be possible?
RodriguezFatz is offline   Reply With Quote
Old   August 9, 2012, 13:57
Amarender
Thank you for the reply.
The machine which I am using has 2gb ram 2ghz core2 duo processor.
I will relax the meshing part a bit so that required memory reduces and then shoot it in the Fluent.
Old   August 9, 2012, 14:05
Philipp
You want to run a mesh with 4.5 million cells on a single machine? Reduce it by a factor of 10 to 450000, even this will take a lot of time.
Old   August 10, 2012, 18:47
Guiliguili
Touré is on a distinguished road
It took me 20G RAM and 8 processors for only 8 millions of cells.
Make a kind of ratio to see the limits of your computer for 4554076 cells.
Touré is offline   Reply With Quote
Old   August 15, 2012, 07:54
vnm
vnm is on a distinguished road
You require minimum of 12 GB RAM for such a karge number of nodes. Either reduce number of nodes or increase RAM of your machine
vnm is offline   Reply With Quote
Old   August 15, 2012, 08:16
Vidit Sharma
Vidit Sharma is on a distinguished road
You need to limit your number of cells up to 2.5 million... or you need a powerful computer to work on..
Vidit Sharma is offline   Reply With Quote
FLUENT - ICEM / Segmentation Violation Error (Hybrid Mesh) Joachim ANSYS 3 April 24, 2016 17:52
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 12:21
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
A error about importing Gambit mesh to Fluent. shin FLUENT 3 November 19, 2002 03:09
Importing a structured mesh into Fluent Flav FLUENT 0 November 30, 1999 11:57
