August 11, 2012, 15:35 |
Solidworks model into Fluent...how to mesh?
I have a swept wing that I made in Solidworks and would like to import it into Fluent so I can run some calculations such as lift and drag and various coefficients. For a 2D airfoil is it straight forward, but for a 3D wing it seems a bit more complicated. I have imported the model as a parasolid using workbench but I cannot see it in the geometry window, but I *can* see it in the mesh window. Another problem I am having is how should I mesh this thing? My first thought would be to create a sort of solid mold in Solidworks that would be used as a 3 dimensional C-Mesh, am I on the right track? Finally, just as a 2D airfoil I do not have to mesh the wing as this will be subtracted from the meshed 3D C-mesh, correct?
EDIT: I have managed to figure out it out, well most of it. I created a mold in solidworks that served as my domain, and have a hollow section inside, the wing, that serves as a wall for Fluent. I then meshed everything in Design Modeller, then imported that into Fluent The problem I am having is how to specify the inlet and the outlet in this region? I cannot seem to be able to select the faces I want in the meshed domain in Fluent, how do I go about doing this? Last edited by cad2blender; August 11, 2012 at 18:36. |
August 12, 2012, 13:10 |
Ryne
Rep Power: 16 |
You need to create named sections in the design modeler and/or the ansys meshing program. Use convenient names like inlet, outlet, and airfoil.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
Importing Rhinoceros 3d model to SolidWorks | george85 | FloEFD, FloWorks & FloTHERM | 21 | March 5, 2014 05:19 |
Exporting structured mesh from ICEMCFD to Fluent? | jeevan kumar | FLUENT | 1 | January 23, 2012 11:21 |
[ICEM] Any successful way of converting Fluent Mesh (academic) to a CAD model? | RossFS | ANSYS Meshing & Geometry | 2 | February 20, 2011 18:59 |
