2D cooling of wavy plate
Old   August 14, 2012, 08:31
Default 2D cooling of wavy plate
Vidit Sharma
Vidit Sharma is on a distinguished road
hey, I am doing a simulation on wavy plate with a hole on it and cold air is coming from the hole, mixing with hot air and making a film on the wall. I am using steady k-e viscous model realizable enhanced wall effects. I am running its mesh with above 5 lakh elements but the problem is that for low y+ i have made spacing near the wall very fine and after doing this even at 0.1 m/s velocity input its diverging even after decreasing the relax-parameters, what should i do? I need to run it at 248 m/s for hot air at 2066k and 95m/s for cold air at 516.6k
Vidit Sharma is offline   Reply With Quote
Old   August 14, 2012, 09:30
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Show us the domain and the mesh you created.
And be a bit more descriptice about the rest of the setup.
flotus1 is offline   Reply With Quote
Old   August 14, 2012, 10:08
Vidit Sharma
This is the mesh i am working on ... Below the wavy wall hot air is flowing from left to right and cold air is coming from the top of small chamber called plenum.
and flowing through the hole....
Old   August 14, 2012, 10:32
Vidit Sharma
Initially I am using first order equation.
Right curve is velocity-inlet, left is pressure outlet at atmospheric pressure, bottom is symmetry, top of the plenum is also velocity-inlet and rest of the curves are wall with default properties.
Old   August 14, 2012, 10:37
Vidit Sharma
I have done meshing in ICEM and the quality is also 0.9 and the spacing near wall is very fine.
The dimensions of the model are:
length- 1000mm
height-200mm
diameter of hole- 1.2mm
height of plenum- 9.37mm
thickness of plenum- 2.4mm
distance between the plenum and the wall is 1.2mm
Old   August 14, 2012, 10:45
Vidit Sharma
I have also checked the Y+ after some iterations which is 0.9 maximum at hole as there is no wall and at rest of the wall it is 0.2
Old   August 15, 2012, 00:08
Guiliguili
Touré is on a distinguished road
How many cells do you have?
What is the size of you minimum cell?
What is your time step and what is the period of the wave approximately?
Touré is offline   Reply With Quote
Old   August 15, 2012, 03:34
Vidit Sharma
Thank you for rply,
This mesh is having 5 lakh cells approximately
The spacing near the wall is 0.67e-04 therefore near the hole the size of minimum cell is 0.67e-04*0.67e-04
Actually I am using steady solver therefore no time step just giving simple iterations..
r u asking period of the wavy plate...??
Old   August 15, 2012, 07:36
Guiliguili
I already had a divergence problem that I had solved increasing the viscosity also. it takes time but you play safe.
Run several simulations in this order for example
0.1m/s and 1 kg/m s
0.1m/s and 0.1 kg/m s
0.1m/s and 0.01 kg/m s
0.1m/s and \mu air = 1.7894e-05 kg/m s
Then, increase the velocity from 0.1 to248 m/s progressively.
If the first simulation of 0.1m/s and 1 kg/m s does not work, you don't have a solver problem.
Old   August 15, 2012, 08:24
Vidit Sharma
thank you...
I will try that...
Flat plate analysis in cfx hamed.majeed CFX 14 February 4, 2015 07:07
HELP! Flow over both sides of a plate. farocean97 Main CFD Forum 0 September 12, 2011 10:57
Need help on perforated plate with less than 2% open area sosososo1114 FLUENT 9 August 31, 2011 01:33
heat transfer on dimpled plate mech FLUENT 4 February 6, 2007 15:15
Parallel Plate Rheometer vs Cone & Plate beginner Main CFD Forum 0 March 19, 2003 11:49
