Home > Forums > FLUENT
slope plane in CFD post
Old   August 15, 2012, 07:38
Thumbs up slope plane in CFD post
Theerawat
Theerawat is on a distinguished road
Hi guys, I want to see the velocity profile but the plane is not xy yz and xz plane. It's 15 degree relative to xz plane. How do I build that plane to look at my profile in CFD post.
Thank you
Theerawat is offline   Reply With Quote
Old   August 15, 2012, 22:39
blackmask will become famous soon enough
you may use surface -> iso-surface to create a surface on the x-z plane and then use surface -> transform -> rotate to move it to the designed position.
blackmask is offline   Reply With Quote
Old   August 16, 2012, 05:20
CFD-student's Avatar
CFD-student is on a distinguished road
The easiest way to do this in my opinion is to find three points on your surface, (all three can for obious reason not lay on a straight line), the under "method" you chose to define the plane from three points...
CFD-student is offline   Reply With Quote
Old   August 16, 2012, 05:35
Default Thankyou
Theerawat
Thank you very much, Is your suggestion used in Fluent or in CFD post. I can't find it in CFD post. could you please explain me briefly.
Old   August 16, 2012, 06:00
If you refer to my reply it is in CFD-post.
Click surfaces > plane
in the lower left part of the screen where you adjust your plane, under method you chose define from three points.
Old   August 16, 2012, 12:08
Theerawat
Thank you for your help very much, Can I ask you about CFD next time. If you say yes, Could you give me an email.
Thread Tools
Trackbacks are On
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 20, 2015 00:40
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. hda ANSYS Meshing & Geometry 2 January 24, 2012 00:21
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 17:25
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
