-   -   Material Properties for Biomass Combustion (http://www.cfd-online.com/Forums/fluent/106014-material-properties-biomass-combustion.html)
Leepox August 15, 2012 08:56
Hi all!
I'm quite new to combustion modelling and after a search through data for biomass properties I have been stuck with the following issues:
1. Most data seems to be bulk density (~400kg/m3), Fluent needs specific density doesn't it (i assume which would be in the 1000kg/m3 range)?
2. Do i assume that latent heat is zero for a combustion case?
3. How do I determine stoichiometric ratio?
4. Can I assume heat of reaction for burnout to be the same as that for coal?
Thanks so much for any help anyone can give!
CFD_Now August 17, 2012 22:14
I'm not familiar with Biomass simulations, you may want to go to www.ansysforum.com, they have some experienced members that might be able to help you out.
Good luck
