spatial variation in heat generation inside a tube wall
Old   August 16, 2012, 01:58
Default spatial variation in heat generation inside a tube wall
n7310889
n7310889 is on a distinguished road
Can any body tell me whether it is possible to declare spatial variation of heat generation in a 3d CHT model? That means heat will be generate at a certain rate, which will vary along y direction of a tube, and this variation can be express by a function.
Thanks in advance to whom, who will answer me the question.
Regards
n7310889 is offline   Reply With Quote
Old   August 16, 2012, 02:38
CFD-student's Avatar
CFD-student is on a distinguished road
I can say this much. It is certainly possible to do this via user defined functions, however it might also be possible to do this using the user defined field functions.
CFD-student is offline   Reply With Quote
Old   August 16, 2012, 07:36
n7310889
Originally Posted by CFD-student View Post
For my 3D geometry (coolant flow inside a tube) I am struggling to accommodate both heat flux input, and radiation and/or convection loss from the tube outside wall in FLUENT window. The heat source is solar radiation (reflected by a parabolic trough). To account heat loss from the surface, I am planning to write an udf declaring either (1) heat flux profile minus radiation and/or convection loss, or (2) activate "Mixed option" in the wall boundary condition dialog box and hook a udf declaring heat generation, which (the heat generation) will vary along the vertical axis of the tube and translate along its horizontal length.
I'm novice in this field. I'll be grateful, if you can suggest me how can I proceed? I'm not sure how can I declare the location/axis of my 3D model to FLUENT. Also if I wanna calculate heat loss, may be I have to include both surface temperature and the ambient temperature.
If I develop an Excel file of the input heat flux including the formulas for heat loss calculation from the surface, how I will hook that Excel file?
You endeavor will be acknowledged.
Regards
Old   August 16, 2012, 08:04
In order to write a use defined function of this nature you will need some basic understanding of C programming. I suggest that you start by taking the UDF tutorial on the customer portal and also consult the documentation for UDF programming. Start by replicating some of the examples given there. Thereafter you will have sufficient knowledge to write an UDF in which you can set the heat flux at the walls as a function of spatial position.
In order to compile UDF:s you will require microsoft NET framework SDK for windows enviroments. More about required softwares can be read in the CFD-online wiki.
Old   August 20, 2012, 01:36
n7310889
Hi CFD-student,
Could you at-least confirm me that whether my plan as I have proposed (in my very last post) to accommodate both of the heat (flux/generation ) and radiation loss is okay or not? Fortunately I've studied some udf from the online resource. My question was how to define the location of the profile on the tube surface in x, y z axes so that the profile vary along vertical y axis on a tubular surface from (z = 0 to 1.5m)? The axis of rotation of the tube is (0,0,0) to (0,0,1.5m).
Thanks in advance
Regards
Old   August 20, 2012, 02:41
Yes, it is certainly possible to do what you propose.
Old   September 5, 2012, 19:12
n7310889
Hi, Primarily, I've written the following simple udf for my 3d model. But the results I'm getting is not impressive. The udf along the z axis seems be working. But I'm not sure whether the x and y axis arguments are working properly or not. I'll appreciate your endeavor to check and suggest me any correction. Another thing I need to ask you is that, radius of the fluid domain of my CFD model is 33 mm. But I'm not sure whether I put the radius 35 mm including the tube in calculation or 33 mm excluding the tube, no matter whether I consider wall thickness (2 mm) in my fluent model or not. The same question is also valid if I assign heat generation profile in the tube body instead of heat flux on the fluid wall surface. For you kind information, the axis of rotation of my semi-annular fluid domain lies between (0,0,0) to (0,0,1.5) of the Cartesian cordinate system.
#include "udf.h"
#include "math.h"
DEFINE_PROFILE(heat_profile,thread,index)
real x[ND_ND];
double z,a,heat_profile;
face_t f;
begin_f_loop(f,thread)
F_CENTROID(x,f,thread);
z =x[2];
if ((z>=0.0) && (z<=1.0))
for(a=0.0; a<180.0; a=a+0.2)
x[0] =0.033*sin(a);
x[1] =-0.033*cos(a);
if ((a>=0.0) && (a<=90))
heat_profile =60000;
else
heat_profile =0.0;
F_PROFILE(f,thread,index) =heat_profile;
else
F_PROFILE(f,thread,index) =0.0;
end_f_loop(f,thread)
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Thin Wall Heat Transfer BC for rhoSimpleFoam swahono OpenFOAM Running, Solving & CFD 12 October 4, 2013 11:49
Heat transfer in circular tube with constant wall heat flux ali radwan ANSYS 0 August 30, 2010 20:30
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
