-   -   simple Liquid jet simulation in an open domain (http://www.cfd-online.com/Forums/fluent/106039-simple-liquid-jet-simulation-open-domain.html)
canev.civelek August 16, 2012 06:40
Hi there,
I am trying to set up a high pressure liquid jet into an air domain.
Previously i used a DPM with injections which was ok.
However i now want to simulate a jet using a multiphase model where i will look into the atomisation process of the jet.
Im not sure i will be able to use injection for this case (as you have to specify an atomisation model)??
Will i need to compile a file for the injection of the liquid.
Please help me with a soloution. It would be much appreciated. :)
tang pan April 26, 2013 22:56
i also want to simulate the process of liquid jet break up,but i am not sure how should i use the model? vof or dpm
miana May 4, 2014 17:17
hi, i need to simulate the liquid jet break up in fluent did you too simulated it if yes plz give me details about it
