What is the most appropriate Method for calculating DPM Concentrations
Old   August 16, 2012, 12:47
Default What is the most appropriate Method for calculating DPM Concentrations
Steve Gronstal
sgronstal is on a distinguished road
I'm using Fluent to investigate the aspiration efficiency of a devices as a function of Particle Diameter.
To do this, I created a bunch of DPM injections (one for each size fraction), and I release them from my inflow surface.
To determine my "base concentration", I count the particle tracks at the inlet and divide by the Volume of flow at the inlet.
To determine the "sampled concentration", I count the particle tracks traversing my Inlet cross section, and divide that by the volume flow rate through the Inlet.
To determine my aspiration efficiency, I divide the two numbers.
I fear that this method might be biased by however, as the injection surfaces does not have a uniform mesh. Is it better to create a new bounded surface to create a more uniform release? Is my method for determining concentration estimates appropriate, or do I need to run a coupled model for each injection?
At this moment, my model uses inert water droplets in Air that trap on all solid surfaces.
Any advice and/or guidance is appreciated.
sgronstal is offline   Reply With Quote
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
Evarporation in DPM method mesumon203 FLUENT 0 February 24, 2010 00:09
Code for most powerfull FDV Method D.S.Nasan Main CFD Forum 6 September 4, 2008 02:08
Help about the preconditioner in gmres method Dan Gao Main CFD Forum 3 July 5, 2008 01:18
problem in MRF and DPM method you FLUENT 1 June 12, 2001 07:13
