Home > Forums > FLUENT
plotting u+ vs y+
Old   August 16, 2012, 20:09
Default plotting u+ vs y+
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
I want to plot the famous TBL curve U+ vs y+on an aerofoil at supersonic speed. M=2. for potting U+ vs y+ I drew a vertical line in the mid chord, sufficiently enough to be in the boundary layer as I see through vector plot. I calculated U+ via formula through custom f/n from U/utau. and utau=sqrt(shear stress/density). When i use wall shear stress option in available functions of Fluent the U+ value was computed to be zero. Then I used tau=mu * (du / dy)y=0. This gave me some value but I still don't get the TBL plot. I get y+ value from 0.01 to 0.6 in the plot as well as maximum in the contour plot range. When I use the log scale it says that no data points in range. Please help me in this regard.
Shamoon Jamshed is offline   Reply With Quote
Old   August 17, 2012, 18:27
Touré
Touré is on a distinguished road
your y+ is too small. Use CFD Online Home -> Online tools -> Y+ estimation or click on http://www.cfd-online.com/Tools/yplus.php
Estimated wall distance is y with this tool.
Y+ for the cell adjacent to the wall is between is 1 for enhenced or 30 for standard turbulent model (See documentation)
Touré is offline   Reply With Quote
Old   August 18, 2012, 09:05
Shamoon Jamshed
The thing is that y+ is although very small but I want to plot the famous curve of U+ and y+ which I dont get. Forget that my y+ is 0.6 lets assume it is 1 then how can I plot U+ and Y+.
Old   August 18, 2012, 14:36
Touré
Check the document at page 19 http://www.stanford.edu/class/me469b...turbulence.pdf
y+ begins in the diagram with 1. I don't think that y+ is defined under this value of 1.
There is a thread for how to compute y+ (FLUENT: variable -. Turbulence -> wall y+) and u+ at y+ and u+ values with low-Re RANS turbulence models: utility + testcase.
You only need to compute u+ with custom functions.
Thread Tools
Trackbacks are On
Plotting a contour of the turbulence production term in CFX-Post kellio9 CFX 4 March 19, 2013 12:34
Contours of 2D plotting therockyy FLOW-3D 4 December 22, 2012 16:04
Graph plotting Lam FLUENT 2 September 25, 2003 07:02
Plotting "in-plane" in 3-D Karl Kevala FLUENT 0 September 6, 2001 17:47
Contour plotting Mark Russell Main CFD Forum 5 April 22, 2000 22:45
