Convergence problem!
Old   August 20, 2012, 19:23
Arrow Convergence problem!
Julian121 is on a distinguished road
Hello
I am simulating a transient problem using Fluent and have convergence problem.
Although I increase the number of iterations per time step, the solution does not converge.
I have attached two screenshots: first: iteration history, 2- lift coefficient
I have tried to decrease the time step, increase the iterations per time step but it seems they cannot affect the convergence.
Have you ever had a problem like this?
Julian121 is offline   Reply With Quote
Old   August 20, 2012, 20:38
Chris, Kam
cartman is on a distinguished road
Hi
there are many approaches to enhance a chance of the convergence
if you could give an information about your problem, that will be nice
(Ps. sorry about wierd sentences , I'm not good at english)
cartman is offline   Reply With Quote
Old   August 21, 2012, 03:10
Originally Posted by cartman View Post
Hi
I'm simulating the flapping and pitching movement of a 3D wing simultaneously. The motion of the wing has been defined using a UDF code.
Specifically, I need to plot lift and drag coefficients curves.
As the solution does not converge, at some point the residuals start increasing and then the curve becomes wavy.
I'm using smoothing and remeshing dynamic mesh methods.
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 03:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 22:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
