-   -   different answers from different UNDER RELAXATION FACTOR (http://www.cfd-online.com/Forums/fluent/106103-different-answers-different-under-relaxation-factor.html)
misagh August 18, 2012 12:39
i have a 2-D micro-channel that a constant heat flux is applied on its walls.
when i change under relaxation factor or discretization of momentum and energy the result(e.g conv. heat transfer coeff.[h]) changes extensively(although the equations have been solved and converged)
what can i do?which under relaxation factor is suitable?
best regards.
Touré August 18, 2012 20:59
Do you have enough elements?
misagh August 19, 2012 06:10
yes, 100'000 elements.im sure the number of elements are enough.
when i change URF in other geometries like macro scale the difference between results is less than 2 %.but in this case(microtube) changes are sever(more than40-50 %).
any guidance is appreciated.
Touré August 19, 2012 08:34
It could be due to the definition of your slip condition. See pages 17 and 18 of http://ethesis.nitrkl.ac.in/1934/1/avinash.pdf
