Home > Forums > FLUENT
Laminar or Turbulent model
Old   August 21, 2012, 07:44
Default Laminar or Turbulent model
prince
prince_pahariaa is on a distinguished road
Hello Friends
How to model a system where flow is turbulent at one part of system and rest part flow is laminar.
prince_pahariaa is offline   Reply With Quote
Old   August 23, 2012, 02:13
Vaze
mvee is on a distinguished road
Hi
This is possible with UDF where you have to tell solver that up to finite length of the domain turbulence model will work and in rest of the domain another model.
I have not yet tried such UDF but it can be possible.
Best wishes
Mvee
mvee is offline   Reply With Quote
Old   August 23, 2012, 06:09
cfd seeker is on a distinguished road
Originally Posted by prince_pahariaa View Post
Hello Friends
Transition is taking place from laminar to turbulent in your system or you have two different flows one laminar and one turbulent at different parts of your system? what exactly is your problem?
cfd seeker is offline   Reply With Quote
Old   August 23, 2012, 06:10
Richard Parker
Richard Parker is on a distinguished road
Simply solve all with a turbulent model. A turbulent model accounts for turbulence, but this does not mean you are assuming the flux is turbulent. It might as well be laminar.
Richard Parker is offline   Reply With Quote
Old   August 23, 2012, 06:25
cfdnewbie
cfdnewbie is on a distinguished road
That would be unwise to do. The standard turbulence models (I am assuming you are doing RANS) add viscosity to the flow, even in the laminar regime. When using a additional turbulence model in the laminar region, you will likely get execessive dissipation there...
cfdnewbie is offline   Reply With Quote
Old   August 23, 2012, 06:32
prince
@ CFD seeker :- Transition is taking place from turbulent to laminar. My problem is like this.
I have a pipe on which 10 nozzles are mounted. This pipe system is to recirculate water in rectangular pool. Water through nozzles goes into pool and there is outlet for water inside pool.
Flow is turbulent inside the pipe and when it passes through nozzle but re- circulation inside pool is laminar. I am expecting at certain height the transverse velocity should be almost zero but i am not getting the desired result.
@ MVEE :- I will try the UDF way. Thanks.. Will let you know if it works.
@ Richard Parker :- I am not very clear what did you suggest. Please can you elaborate a little..
Old   August 23, 2012, 06:37
exactly cfd newbie is spot on that turbulence models add viscosity everywhere....if the flow is transitional then we can use 2 new turbulence models incorporated in Ansys 12 onward i.e k-kl-w transition model(3 equations model) and transition k-w model(4 equations model) but in the other case if we have two separate flows one laminar and other turbulent then I guess we have to split the domain in two parts to solve laminar and turbulent portions separately
Old   August 23, 2012, 07:05
Richard Parker
Perhaps it is not necessary to write an UDF. Fluent has the capability of defining a laminar zone, where turbulence equations are not solved. You just have to define the zone in the mesh and then mark is as a laminar zone in the Fluid panel of the GUI. Have a look here. (I must say that I've never done it myself, but looks promising).
About the consequences of solving laminar flows with a turbulent model whe have a good old post with a very knowledgeable insight.
Old   August 24, 2012, 00:46
prince
Thank all of you for interest..
It has been useful
Thread Tools
Trackbacks are On
Turbulent Model simon CFX 3 December 18, 2008 17:35
turbulent or laminar Novice FLUENT 1 October 8, 2008 09:39
Half laminar and turbulent model trying to solve Andrew Clarke FLUENT 5 May 19, 2008 13:40
The difference between Laminar model and DNS at lo fpz FLUENT 3 March 14, 2005 07:33
