-   -   Heat transfer simulation of Gel(high viscous fluid) on a solid plate (http://www.cfd-online.com/Forums/fluent/106218-heat-transfer-simulation-gel-high-viscous-fluid-solid-plate.html)
fshak92 August 22, 2012 06:12
1 Attachment(s)
Hi everybody,
Im going to have the thermal simulation of a high viscous fluid(acting like gel) which lie on a solid plate.
Im not sure whether i should define my fluid layer as fluid with high viscous?
Because this layer has the thickness of (e.g 1 cm) and if it defined as a fluid,how can it be maintaned in a fixed shape on a solid plate?(you can see the picture below)
Also this layer would be warmed and in future i like to consider the density changes of that.
Thanks in advance.
fshak92 October 26, 2012 11:32
Hii,
Nobody has any idea?
