Multiphase flow dynamics at transitional flow
Like Tree1Likes
  • 1 Post By pleasantsandy
Old   May 30, 2012, 01:22
Default Multiphase flow dynamics at transitional flow
sandip
pleasantsandy is on a distinguished road
What should be the best turbulence model for a critical flashing flow across a huge pressure difference ( like from 100atm to 1atm) through a very minute pipe leakage of very low hydraulic diameter ( ranging 10e-5 m) with water at temperature around 250 degrees within the pipe
Also density based solver could be good for such high mach no. compressible flow domain but that solver does not support boiling models (supported by eulerian pressure based solver models) which are predominant in such cases. So kindly somebody suggest the best solver model for such pipe leak situation.
moloykb likes this.
pleasantsandy is offline   Reply With Quote
Old   August 27, 2012, 06:59
Dr. Moloy Kumar Banerjee
moloykb is on a distinguished road
dear pleasantsandy,
can you simplify your problem ?
moloykb is offline   Reply With Quote
LES transitional pipe entrance flow hasanduz Main CFD Forum 2 October 11, 2013 17:59
Multiphase flow! Amer FLUENT 2 May 16, 2012 15:57
Multiphase Flow Pavlos FLUENT 0 August 8, 2011 08:43
Multiphase flow in atomiser santhosh1987 FLUENT 0 May 12, 2011 04:26
multiphase flow, aeration Ellie CFX 3 January 15, 2009 17:33
